McGuire1986
Hi all,
I purchased a laptop several months ago however, the screen is now damaged and i need a replacement. What i need to know is:
1. When replacing a laptop screen do you need replace with a specific screen or can any screen work as long as its the correct size?
2. Where is the best place to purchase a laptop screen replacement from? All i need is the screen as i will replace myself. The laptop i purchased has the Genesis IV: 15.6" Glossy Full HD LED 16:9 Widescreen (1920x1080)
Thanks
Thanks
