laptop won’t turn on but power button is on
honxrr
I’ve had my laptop since November. It was working yesterday and when I was finished with it I went to shut down but let it update first. I left it on charge overnight. I tried to turn it on this morning and first of all it turned on with three grey bars. I restarted it and now when I try to turn it on, the power light turns on and the fan turns on for a few seconds then turns off. If i keep it on the fan turns on again after a few minutes, then turns off again. The keyboard isn’t working at all either to turn backlight on or anything.
Not sure if it’s related, but screen has been a little glitchy now and then the past month or so, mostly when I switch to a different application. The speakers are also a little difficult sometimes and if i get any notifications, or sometimes just randomly, the volume will go very quiet or off completely and I’ll have to go into sound settings and click on the speaker again.
Not sure if there’s a defective part in it or something that could possibly be changed out, just wondering if anyone has any ideas of what it could be or how to fix it
honxrr
can you post your specs from your orders page
Chassis & Display
Optimus Series: 17.3" Matte Full HD 120Hz 45% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Six Core Processor 10750H (2.6GHz, 5GHz Turbo)
16GB Corsair 2666MHz SODIMM DDR4 (1 x 16GB)
NVIDIA® GeForce® GTX 1650 Ti - 4.0GB GDDR5 Video RAM - DirectX® 12.1
2TB SEAGATE 7mm SERIAL ATA III 2.5" HARD DRIVE WITH 128MB CACHE (5,400rpm)
128GB PCS PCIe M.2 SSD (1100 MB/R, 600 MB/W)
Integrated 3 in 1 Card Reader (Full Size SD / SDHC / SDXC)
AC Adaptor
1 x 150W AC Adaptor
2 x 1 Metre Cloverleaf UK Power Cable
Battery
Optimus Series Integrated 46WH Lithium Ion Battery
1 x USB 3.1 PORT (Type C) + 2 x USB 3.1 PORTS + 1 x USB 2.0 PORT
Keyboard Language
OPTIMUS SERIES RGB BACKLIT UK KEYBOARD
Keyboard & Mouse
Webcam
INTEGRATED 1MP HD WEBCAM
Chassis & Display
AC Adaptor
1 x 150W AC Adaptor
Battery
Keyboard Language
Keyboard & Mouse
Webcam
I would raise an RMA, that sounds like a hardware issue.
I'd take the back off and check all the internal connections and pop the drive and RAM out and put it back in
