Laptops with ethernet port?
bruv
Hello all,
I need a laptop for work which has an ethernet port - these usually only come with gaming laptops these days, is there a list of each laptop pc specialist does that can be configured to have one? I know you can use USB adaptors but they're annoying and I'll end up losing lol
A bunch of USB ports is also preferable, as is a decent processor
Hello all,
What do you need it for? Does it need to have a dedicated GPU?
What's the maximum budget?
bruv
Max budget about a grand - I should have been more clear I don't want a laptop with a GPU as I need it sort-of lightweight and GPUs add an extra kilo or so onto the weight
Might ring em up and see if there's a mobo/chassis I can purchase without a dedicated gpu
bruv
In short... there isn't a list you'd need to just take a look at each one and see.
As Spyder noted though there's arguably more important considerations (at least I'd argue they're more important...) :)
But I can't filter by the number of and/or available ports so I have to go through the whole configuration of each laptop 😭
Rakk
The Awesome
Unfortunately the same applies to everyone here, including the mods, the mods are mostly just volunteers so we can only see and filter by what you can :(
