Led Installation on CPU
guispfilho
Hi, I'm new on the forum so forgive me if I miss placed this thread!
I'm having some problem to install some led I bought recently. I've watched lots of videos on the matter but my led model seems to be different:
How to cut, connect & power LED Strip Lighting
How to Add LED Lights to a PC / Computer Case
In all videos I saw they welded the wires in the little spots marked with the negative and positive poles. However the model I acquired doesn't have those spots:
My Led Model
So... I'm guessing I should weld the led to the wire via the copper section meant to be cut as well?
Here?
But still, there's no negative/positive pole reference, so... I don't know what to do.
Any help will be mostly appreciated, and thanks for your time.
steaky360
If your strip is long enough I'd suggest cutting a short section and testing - that way you can determine which side is which. Just remember to use the correct cables and voltage etc. for the LED's
