Lookinf for Advice on build
Zzwebsc12
Hi there, im just looking for some advice on my build as I'm extremely new to pc gaming. What would yous upgrade first? I have a 8GB nvidia geforce rtx 3060ti GPU
Intel® Core™ i5 Six Core Processor i5-11600KF (3.9 GHz) 12 MB Cache
GIGABYTE Z590 UD AC (LGA1200, USB 3.2, PCIe 4.0, CrossFireX, Wi-Fi) - ARGB Ready
PCS FrostFlow 150 Series High Performance CPU Cooler
MMDos
First off all, Intel 11th gen is not worth it. Either go for Ryzen Zen 5000 series or Intel 12th gen.
Second of all, we need your budget, what kind of monitor you will be using, and maybe some examples of the games you want to play
Bigfoot
Grand Master
Is this a PC you already have that you are looking to upgrade or a spec for one you intend to buy? In either case we need the full spec. If you are looking to upgrade, what areas are you seeing a lack of performance in?
