I have had a Desktop PC from PCS since 2019.
I want to upgrade the case to something a lot more modern in appearance, as well as during the hot summer months I also often find myself having to remove the side panel from the case as the system can become far too hot. Removing side panel can greatly reduce GPU temps, I figured I could kill two birds with one stone so to speak, and was hoping I could upgrade the case to one that supports more fans.
The main heat generating component I believe is my 6GB NVIDIA GEFORCE RTX 2060. It is not overclocked. But seems to kick out a lot of heat that doesn't seem to leave the case very well. At 100% load the GPU temps can go up to around 75c max in the summer with the side panel off. If panel is left on, the GPU can hit as high as 83c, which is why I feel the cooling and/ case could be a lot better.
My CPU is an Intel® Core™ i5 Six Core Processor i5-9600K (3.7 GHz), which doesn't ever seem to go above 60-65c under full loads with its current CoolerMaster MasterLiquid Lite 240 High Performance Liquid Cooler with 3 fans pulling heat out the heat sinks at the top of the case pretty well.
Is what I speak of something that can be done via PCS upgrade option? I don't seem to see an option to do this in upgrade section
Any thoughts and advice is greatly appreciated! thanks!
