Looks like Halifax are going to give me a loan then :)
I3astards
I don't really want to spend over £850. Can you cast an eye over the below please?
COOLERMASTER ELITE 310 BLUE CASE
AMD PHENOM II X4 970 (3.50GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
1280MB NVIDIA GEFORCE GTX570 - 2 DVI,mHDMI - DirectX® 11, 3D Vision Ready
2nd Graphics Card
NONE
Memory - 1st Hard Disk
1TB WD CAVIAR GREEN WD10EARS, SATA 3 Gb/s, 64MB CACHE
2nd Hard Disk
NONE
RAID
NONE
1st DVD/BLU-RAY Drive
2nd DVD/BLU-RAY Drive
NONE
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£78)
Sound Blaster® Audigy™ SE (£19)
I have gone for the £5 warranty option too.
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE CPU COOLER - will this actually make much difference on cooling performance??? is it needed? Im not too bothered by noise really but if the cooling power is a lot better than standard then i will get it!
Cheers!
Freeley
Looking nice mate, i think it's more a quietness thing rather than cooler that the stock cooler but what the hell do i know?!
Anyhow for £19 why not? I've got it on my spec.
PCS
Administrator
Staff member
Great spec, just about ready to go! :)
You don't need the SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE CPU COOLER but if you want it, it will help decrease your CPU temperatures.
I3astards
Thanks guys. Its all about the NVIDIA GEFORCE GTX570 !!! From the reviews etc it sounds like a really good card and not silly priced.
Thanks for the comments on the Cooler, for £19 I think I will stick with it.
Regarding the Sound Blaster® Audigy™ SE, will this give better sound quality than the stock one??? Cheers again.!
PCS
Administrator
Staff member
The soundcard is not really required - the onboard audio is usually more than sufficient.
I3astards
Also, will the 650w PSU be enough for the GTX570????? The spec checker on the PCS website says its ok but on a few websites people suggest 800w!?? comment pls!
JSG10
Expert
A soundcard isn't really necessary unless you are a complete audiophile, normal users really won't notice the difference.
And yes 650W will be enough, I'm using the same with a GTX470 which uses more power
