Mass Effect Problems
jackguinea
hi there
you may have noticed that almost all my threads are due to problem sbut i recently installed mass effect and when i double click the short cut it opens then stops responding and closes down. Any help/advice?
Kalisnoir
Super Star
Good stuff, what did you do to fix it, that way if anyone has the same problem (and are wise enough to use the search feature) they can see it :)
jackguinea
Well I was a bit impatient and decided to search the web for solutions instead of waiting for action centre to help me but in the end it alerted me that i had to download an update for mass effect. After downloading this update my game was fine and i haven't had a problem since.
