Maximum speed of RAM in a SkyFire 14 (2014)?
I bought a SkyFire 14 laptop from PC Specialist in 2014.
It came with an Intel Core i5-4210M, 1x 8 GB DDR3-1600 RAM, a GeForce GTX 850M GPU and a 1600x900 display.
I've already upgraded the screen to a brighter, 1920x1080 display and an Intel Core i7-4712MQ CPU and now I'm looking to upgrade the RAM to 16 GB.
Does anyone know the maximum speed of the RAM supported by the system? If it's DDR3-1600, I'll just grab another SODIMM of the same.
The UEFI states MSI Whitebook MS-1492 and Aptio Setup Utility.
Crucial will sell you 2 x 8gb 1866MHz, which sound about right. But that's about £85, whereas another stick of what you've got is under £40 and I'm not sure the extra MHz are worth the difference unless something like WoW is your main game you're really into it.
