Mini all-round PC spec help
Sabalos
Hello.
I'm (somewhat unexpectedly) moving into smaller, temporary accommodation in the next few weeks, which means leaving my big friendly desktop monster at home, and I've been looking at speccing a mini PC to take with me. I basically want something smaller and easy to transport that can do everything I need and not overheat and die.
Anyway, as usual it's been a few years and I'm completely out of the loop, plus I've never had a mini pc before.
Monitor: probably 2x Samsung SE450 (S24E450B) - 1920x1080, 60hz. I haven't bought these yet though, so if you have a better recommendation go for it; main thing (for work reasons) is that they can swivel to a vertical orientation)
Uses: primarily work (lots of word processing, browsing/research and a few specialised programs, but no photoshop, video editing, etc.) and movies/music (hence the BR drive (I guess integrated drives aren't possible with mini cases?) and speakers, though I'm not sure about what speakers yet). I do play some games, but nothing very high performance (Disco Elysium level, will probably be the newest/flashiest thing I'll be playing). Will need to be able to connect to wifi I guess
Budget: I suppose £1000-1500 is what I'm hoping to spend, could maybe be persuaded to go a bit higher if needed. Not bothered about high-end gaming or things like that, but I do like to have something fast and clean and slightly more powerful than I 'need'. But also don't want to accidentally spend hundreds more than necessary haha
Open to suggestions, rip the whole spec up and start again if you want.
Samsung SE450 Series S24E450B​
Uses:
FRACTAL DESIGN NODE 304 Mini ITX Case
GIGABYTE A520I AC: Mini-ATX, AM4, USB 3.1, 6GB/s - RGB Ready!
4GB NVIDIA GEFORCE GTX 1050 Ti - DVI, HDMI, DP
256GB PCS 2.5" SSD, SATA 6 Gb (500MB/R, 400MB/W)
4TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 5400RPM, 256MB CACHE
External DVD/BLU-RAY Drive
6x Slim USB 2.0 External Blu-Ray Writer
CORSAIR 450W CV SERIES™ CV-450 POWER SUPPLY
STANDARD AMD CPU COOLER
GIGABIT LAN PORT + Wi-Fi (Wi-Fi excluded on A320I-K)
Keyboard & Mouse
LOGITECH® K120 USB KEYBOARD
Speakers
LOGITECH Z333 2.1 SPEAKERS
Price: £1,157.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-sff-gaming/RPGBe4KyGY/
