Mirage will it work?
Music Guy123
I would recommend this:
Chassis & Display
Xenon: 14.1" Glossy HD LED Backlit Widescreen (1366x768)
Intel® Core™i5 Dual Core Mobile Processor i5-2430M (2.40GHz) 3MB
4GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (2 x 2GB)
Intel® HD Graphics 3000 Video Memory Technology up to 1.7GB
Memory - Hard Disk
120GB INTEL® 320 SERIES SSD, SATA 3 Gb/s (upto 270MB/sR | 130MB/sW)
DVD/BLU-RAY Drive
Bluetooth & Wireless
GIGABIT LAN & WIRELESS 802.11N CARD INC. BLUETOOTH 3.0
3 x USB 2.0 PORTS AS STANDARD
Battery
Xenon Series 6 Cell Lithium Ion Battery (48.84WH)
Power Lead & Adaptor
1 x UK Power Lead & 65W AC Adaptor
NO OPERATING SYSTEM REQUIRED
NO OFFICE SOFTWARE
Keyboard Language
INTEGRATED UK KEYBOARD
Notebook Mouse
Webcam
INTEGRATED 1.3 MEGAPIXEL WEBCAM
Insurance
Quantity
1
Price: £515.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/notebooks/xenon/
I don't quite know how but it is cheaper than yours and a lot more powerful. I didn't put an os on it though as you seem to be pretty set on ubuntu.
Wozza63
Biblical Poster
if you are ever going to consider getting another 4GB of RAM, then get the 1x4GB setup
you could also drop to an i3, not much difference in speed
Tom DWC
Tom what version was you using?
And was was it all round performance or on specific tasks?
Thanks btw
All round performance.
Ubuntu 11.10 32-bit (desktop edition, I find the netbook edition too minimalistic). Even so I would of expected more to be honest, the mirage is somewhere between netbook and fully fledged laptop.
Might improve if you tweak it, I just tested it quickly from an out of the box installation for 30 mins.
Tom DWC
Also you mentioned a battery test, I don't know how busy PCS are atm, either way you can never have too many benchies so as it's fully charged right now happy to run a battery test for you? Just let me know if you want idle, full load (or both :p).
It's still very new I've only run it down fully twice.
amosela
Thanks Tom :)
I would be using desktop edition :p
If you could do a full load test that would be fantastic I would really appreciate it.
Once again thanks Tom
Wozza63
Biblical Poster
try it, you may be pleasantly surprised, seeing as mine works great and i get double the battery life compared to when i had windows 7
Tom DWC
I will do if I get the time, never know I spose. It wasn't just a little bit slower though, it was miles slower and decided to randomly lock up at times too. Unity bar was horribly unresponsive. Might just be a hardware compatibility issue with AMDs APU chips cause graphics performance was poor as well e.g. Windows 7 streams HD iplayer and 720p youtube no problem wheras Ubuntu struggled. Plugin possibly?
7 runs like a dream in comparison so I think it justifies the cost.
Wozza63
Biblical Poster
i acutally think you may have the same problem i had, im guessing you installed via a memory stick/CD? try it on a memory stick if you did it with a disc before, my disc ended up being faulty and it was incredibly slow when installed, done it from a memory stick and works great
Intel 2.1GHz Dual Core
3GB RAM
Integrated gfx
Tom DWC
@Wozza
Used a USB but if I try another install I'll bear that in mind. :)
@amosela
Windows 7 x64 - specs in sig - 100% charge set to balanced power mode. All other programs closed. WiFi On.
Prime95 using blend mode: CPU @ 100% stress and high RAM usage.
Tom DWC
Netbook surrendered to torture after 1hr 42 minutes.
Would expect an improvement with a lower speed HDD or dedicated SSD.
Should give you a rough idea as to how it fares regardless of OS.
PCS
Administrator
Staff member
We have built a spec to test the battery. Would you like an idle test?
