Monitor help please
TimW
My pc spec includes the Nvidia Geforce RTX 2060 graphics card.
I'm thinking of purchasing a second hand Dell monitor with these connections: "VGA (Analog), DVI-D (Digital) x 1 with HDCP"
Is that compatible with the outputs of my graphics card?
Appreciate any advice,
Thanks, Tim
Thanks, Tim
That’s a very old monitor and those connectors aren’t used any more. You can still use it but you’d have to get a display port to dvi adapter or hdmi to dvi adapter. Don’t use VGA.
TimW
Would this work? (It's a Dell P2217H)
1 x DP (ver 1.2)
1 x HDMI (ver 1.4)
1 x VGA
1 x USB 3.0 port - Upstream
2 x USB 3.0 ports - Side
2X USB 2.0 – bottom.
1 x DP (ver 1.2)
1 x HDMI (ver 1.4)
1 x VGA
Yes, that’s much more like it, you could use either display port (DP) or HDMI.
