Monitor or monitors?
Jack Guinea
Hi i recently discoverd that if i want 3 monitors then the max screen size would be 20inch so shall i go for 3 20inch monitors or one big monitor. Whateve you recommend could u also recomend a monitor
tom_gr7
Life Serving
why would you be limited?
you can have higher than 20inch? Im sure theres a few who have three 22inch.
Kalisnoir
Super Star
. Or should i go for a bigger 3d monotor?
Only you can make that choice, be no point in us telling you to get a 3D monitor if you didn't want to use 3D lol.
Also in reply to the original post, the same thing applies, do you want multiple monitors or 1 big one? I personally prefer my 28" on its own, not keen on multiple monitors due to the frames.
NMEBowen
Master Poster
you may find that you will still fit 22/23 inch monitors as the benifits of having 3 displays over 1 large one is the fact you can have the 2 outer displays at an angle, the idea being when playing games you use these outer displays for peripheral vision the center display is still the main display you will use as if you do notice anything in these outer displays you will be sweeping this image from the outer display to the center.
