This will be used for work and some play, to last maybe 4-5 years.
Programs used - Autocad (2d) sketchup, photoshop, illustrator, indesign, ms office, some gaming...need to have lots of programs open at once...
For processor, not sure between i4790k (OC 4.5?) or i4930k (OC 4.5?) or a Xeon...? is it worth OC?
GPU - Reading Toms hardware, not sure that quadro cards are any better for Autocad, but better for 3d rendering, not sure with sketchup/photshop if there is an advantage one over getting a good gaming card? GTX 770 4mb?
anyone have experience of quadro k2000 or k4000 for gaming or standard use? can you mix a cheaper quadro with a gaming card? will it be worth it?
Ram - 16-24mb 1600mhz
Want it too be as quiet as possible...which Case, cooling?
Was thinking about 2 x SSD - one for os, one for files?
Also maybe 2 x 2tb HD - mirrored...will that slow things down? is it easier to backup up manually?
Would like a new monitor...24" something that can get really tight resolution?
Thanks
Thanks
