Need a build, max budget of 800 pounds.
bragor
Please post me a pro GAMING pc build, for the top budget of 800 pounds, i was thinking of buying a pc from tescos i dont know if its any good for gaming?
ache Memory in Mb 4MB
Card Reader Type Memory stick, Memory stick duo, Memory stick pro, SD, xD
Crystal Bright Screen Monitor No
Dial-up Modem No
External Sata Interface No
Features of Product HDMI connectivity for full high definition video and audio output. 19-in-1 media card reader for easy transfer of digital media to the PC. Huge 1TRB HDD to store all your favourite photo's and music. New! Intel® Core™ i5-650 processor for the power you need. On the front of the machine it has2 USB ports, headphone jack and Microphone jack for easy access.Firewire - 6 pin.
Graphics Chipset ATI Radeon HD 5450 1GB
Graphics Type Shared
Hard Drive Capacity 1TB
Hdcp Compliant Monitor No
Headset Included No
Hotkeys On Keyboard No
Joystick On Keyboard No
Keyboard Included Yes
Matt Screen Monitor No
Media Centre Ready Keyboard No
Media Centre Ready Mouse No
Memory Slots Total 4
Memory Type DDR3
Monitor Energy Star V5 Compliant Yes
Mouse Included Yes
No of PCI Slots 1
No of Pci-e 16x Slots 1
No of Pci-e 1x Slots 2
Number of USB Ports 8
Operating System Microsoft Windows® 7 Home Premium 64 bit
PokerFace
Banned
How much is this system. If it's anywhere near £800 then I'm sure a mod (or other learned person) will be here shortly with a much better gaming rig for around that price.
I think I've decided on my final build (£829) and will probably be posting it in a new thread on Friday, for some last minute approval (hopefully!). I just need to do a final bit of research :rolleyes:
cheezing
I would avoid buying from Tesco's. Most of their parts are probably non branded or at least very unreliable.
Here is the spec I ordered from PCS a few days ago and will be fine for my gaming needs. Cost is £799.
COOLERMASTER ELITE 310 BLUE CASE
Intel® Core™i5-760 Quad Core (2.80GHz, 8MB Cache) + Turbo Boost
ASUS® P7P55D-E: USB 3.0, SATA 6.0GB/s, CrossFireX™ SUPPORT
1GB ATI RADEON™ HD 6850 PCI EXPRESS - DirectX® 11, Eyefinity 3 Capable
2nd Graphics Card
NONE
3rd Graphics Card
NONE
Memory - 1st Hard Disk
640GB WD CAVIAR GREEN WD6400AARS, SATA 3 Gb/s, 64MB CACHE
2nd Hard Disk
NONE
RAID
NONE
1st DVD/BLU-RAY Drive
2nd DVD/BLU-RAY Drive
NONE
Power Supply & Case Cooling
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£76)
Network Facilities
Modem
NONE, I WILL BE USING BROADBAND
Floppy Disk Drive
NONE
Firewire & Video Editing
NONE
TV Card
NONE
NO OFFICE SOFTWARE
Monitor
NONE
2nd Monitor
NONE
DVI-D & HDMI Monitor Cables
NONE
Eyefinity / GeForce 3D Vision
NONE
Keyboard & Mouse
Logitech® Wireless Desktop® MK250 Keyboard and Mouse Combo (£19)
Mouse
NONE
Speakers
NONE
Webcam
NONE
Headsets (VOIP)
NONE
Surge Protection
NONE
Printer
NONE
External Hard Drive
NONE
Home Installation
NONE
Rakk
The Awesome
'Tesco Value' PC ........
Ewwwww!
That's just so very wrong :)
cheezing
Define pro build?
If you want the best of the best components for gaming then you're having a laugh if you can buy it for 800. GTX 580 card costs 400 quid alone. Even by building it yourself it would cost £1000+
bragor
There'sa pro build for every budget, meaning getting the best item's for ur budget. Meaning its a PRO build for you.
Phoenix
Cheezings' build looks good but I'd go for something like this instead:
AMD PHENOM II X4 955 (3.20GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M4A89TD PRO/USB3 : DDR3, USB 3.0, SATA 6.0Gb/s, CrossFireX
1GB AMD RADEON™ HD 6870 PCI EXPRESS - DirectX® 11, Eyefinity 4 Capable
CORSAIR 750W TX SERIES (TX750) 80+ ULTRA QUIET PSU (£88)
STANDARD AMD CPU COOLER
Network Facilities
Standard Build - Approximately 9 to 13 working days
Quantity
1
Price: £798.00 including VAT and delivery.
While both builds will be far better than the awful tesco PC this one has a better motherboard which is more suited to running two GPU's as well as having a HD6870 instead of a HD6850 which will not only provide more FPS now but will provide more performance when a second card is crossfired. I changed the power supply to the TX750 because while a TX650 will be just about ok for two HD6870's there may be issues if any other devices are added.
  • Like
Reactions: PCS
