lateralus987
Sorry i find this quite overwhelming with the amount of options, so any advice would be much appreciated!
Background - bought my previous PC from overclockers. Was very expensive and high end at the time (and overclocked) and lasted me a decent while (must have got it at least 3 years ago), but there have been intermitant issues and now it doesnt boot most of the time (and i've tried to solve the issue with no luck), so looking to get a replacement. Dont need anything high end - these days i mainly play EU4 or Civ6, but i want something that will last a few years. Most importantly, without issues! Long story short i had real overheating issues (random restarts) so turned off overclocking. Then my graphics card (Radeon HD 6950) died so i replaced it with a £50 card off amazon (which is somehow working well enough!).
Current specs: i5-2550k @3.4ghz CPU, 8Gb ram.
I run two monitors, and not really bothered about upgrading them. I plan to move over my 2 hard drives but thats all from my current set-up (will probably want a new hard drive also, around 2TB, maybe a hybrid dependant on cost).
So my questions:
1) Case - there are so many options! Does it really make a difference? I dont want one with annoying bright lights on the front, it will be in my bedroom
2) Intel vs. AMD. No idea - does it really matter?
3) CPU - is the I5 option an upgrade from what i currently have?
4) Memory - what is the difference between the options (they have a higher number not aligned to the Gb size [sorry my knowledge is limited!]) - does it really matter?
5) Graphics card - any recommendations? My previous one had funky copper tubes coming out of it - i just want something simple! But it needs to run two monitors, one with a white and one with a blue cable
Thanks in advance for any help - please let me know if you need any further details.
So my questions:
