Nice might have to copy and get that beast!!
Changing the subject for a min to my person pc do u think fan filters are worth getting on a push and pull config also on the other fans?
filters on a push pull config? nah not really, ya will get dust in there though but cant be helped.
dust filters on fan intakes, definitely. But before you buy some post here, as personally I have bought a load of filters and most of them are crap, so post just to check ya not buying the same ones as I wrongly bought.
COOLERMASTER CM STORM TROOPER - GAMING ENTHUSIAST CASE
Intel® Core™i7 Six Core Processor Extreme i7-3960X (3.3GHz) 15MB Cache
ASUS® RAMPAGE IV EXTREME: INTEL X79, SOCKET 2011, R.O.G
32GB KINGSTON HYPERX GENESIS QUAD-DDR3 1600MHz X.M.P(8 x 4GB KIT)
2GB NVIDIA GEFORCE GTX 680 - 2 DVI, HDMI, DP - 3D Vision Ready
240GB INTEL® 520 SERIES SSD, SATA 6 Gb/s (upto 550MB/sR | 520MB/sW)
2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
RAID 1 (MIRRORED VOLUME - 2 x same size & model HDD / SSD)
12x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW
CORSAIR 1200W PRO SERIES™ GOLD AX1200-80 PLUS® GOLD MODULAR
INTEL CERTIFIED LIQUID CPU COOLER FOR SOCKET LG2011
NZXT Sentry 2 Fan Controller with upto 5 Fitted Case Fans
Creative Sound Blaster Recon3D Fatal1ty Professional
Genuine Windows 7 Professional 64 Bit - inc DVD & Licence
ACER 23" GR235HAbmii PASSIVE 3D-READY LED MONITOR (1920 x 1080)
NVIDIA GEFORCE 3D VISION 2 WIRELESS STEREOSCOPIC KIT
LOGITECH® G110 GAMING KEYBOARD WITH BACKLIGHTING
LOGITECH® G9X LASER GAMING MOUSE
CORSAIR GAMING AUDIO SERIES™ SP2500 2.1 PC SPEAKERS
