Need help for a new pc
Qishlo
Hi !
I'm thinking about building a gaming pc, but this is the first time that i actually get to choose my components. I will mainly use it to play in 1440p at ultra settings and my budget is max 1700 euros. What do you think about my config ? Any advices ?
Boîtier
BOÎTIER MOYEN TOUR GAMING NZXT H511 (BLANC)
Processeur (Unité centrale)
Processeur Six Core Intel® Core™ i5 i5-10600K (4,1 GHz) 12 Mo de cache
Carte mère
ASUS® TUF Z490-PLUS GAMING (LGA1200, USB 3.2, CrossFireX) - Compatible ARGB
Mémoire (RAM)
16 Go Corsair VENGEANCE DDR4 3200 MHz (2 x 8 Go)
Carte graphique
8 GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP
1er Disque de stockage
1 To SSD PCS 2,5 POUCES, SATA 6 Go (520 Mo/R, 470 Mo/W)
1 To SEAGATE BARRACUDA SATA-III 3,5 POUCES HDD, 6 Go/s, 7200 T/MIN, 64 Mo DE CACHE
Alimentation
CORSAIR 750 W TXm SERIES™ SEMI-MODULAIRE 80 PLUS® GOLD, ULTRA-SILENCIEUX
Câble d'alimentation
1 câble d'alimentation européen, 1 m (C13/14)
Refroidissement du processeur
Système de refroidissement liquide haute performance CoolerMaster MasterLiquid Lite 120
Luffy
Sorry Had a hard time understanding that because it was in French but why don't you get an AMD Based computer. Much better and reliable then Intel's falling performance
Qishlo
Thanks for your reply ! Well i went for intel because im not really informed about AMD processors and concerning the graphic card, it is mainly for DLSS but i'm open to suggestions, what kind of config from AMD would you recommend for my price range ?
This AMD spec would eat the Intel for déjeuner...
COOLERMASTER MASTERBOX MB530P RGB GAMING CASE
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP
STANDARD AMD CPU COOLER
Firefox™
2 DAY DELIVERY TO FRANCE
Price: 1 691,00 € including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/bWftpzRtqt/
