Need help on which PC Gaming unit to buy??
JadeD
Hi my Nephew is wanting a pc gaming unit for Christmas and i have no idea which is best. He was wanting the Neonzilla - Intel Core i7 12th 16GB NVIDIA RTX 4060 8GB #NV-160SE, as his friend has this but this is way over my budget!
I'm looking at something around £500 - £600, He plays games like Fortnite, Call of Duty, Roblox.
Any help is much appreciated :)
You are not going to get a gaming PC at that budget, and we'd can't comment on the Neonzilla as this site is dedicated to pc specialist customers and we can't comment on competitor builds which the Neonzilla is
£500-£600 you're not getting a gaming machine mate unfortunately, at that budget you're much better buying a console. It'll be a far greater experience
For entry level gaming you're talking around £900-£1000 at a push, that would be a very tight budget. Anything you buy at the 500-600£ mark will be less than sub par experience, unless you can get a cracking deal on a second hand system which unfortunately we can't help with here
