Hey guys, I am in the process of getting ready to order my new gaming PC.
Are the current choices I have made going to result in any performance bottle necking?
Namely, Will the Motherboard / cpu / gfx card / ram / cooling systems/ case fans / case / SSD all going to get along as a happy (no bottle necking) family? Would a small upgrade to one of these vastly improve the over all performance?
Case COOLERMASTER CM690 III ADVANCED CASE (GREEN)
Overclocked CPU Overclocked Intel® Six Core i7-5820K (3.3GHz @ MAX 4.4GHz)
Motherboard ASUS® X99-A: ATX, HSW-E CPU, USB 3.0, SATA 6 GB/s
Memory (RAM) 32GB Corsair Vengeance DDR4 3000 MHz X.M.P (4 x 8GB)
Graphics Card 8GB NVIDIA GEFORCE GTX 1080 - DVI, HDMI, 3x DP - GeForce GTX VR Ready!
1st Hard Disk 500GB Samsung 850 EVO 2.5" SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
Power Supply CORSAIR 750W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET (not sure if this is overkill, says I only need 650, but was worried that overclocking of anything else in future such as the gfx card, or adding a sound card etc would need the extra?)
Processor Cooling Noctua NH-D15S Ultra Quiet Performance CPU Cooler
Extra Case Fans 2x 120mm Apache Black Quiet Fan (fitted to extract from rear/roof)
Sound Card ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking 10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
USB Options MIN. 2 x USB 3.0 & 6 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating System Genuine Windows 10 Professional 64 Bit - inc DVD & Licence
I also had a worry as to if the overclocked CPU would be sufficiently cooled by a CPU fan (plus thermal paste) and 2 internal fans?
I also hope it all fits in the bloody case!
Any insight would greatly be appreciate people, as well as a brief explanation on any points you make.
Hope you're having a great weekend
All the best
Rob
All the best
Rob
