The D3 error 'some of the artichitectural protocols are not available' is to do with the pre initialization of how the system works before you can get into the UEFI BIOS is available and the DXE boot.You will find the meaning of those codes at the back of your motherboard manual which should have been included in your welcome pack..the codes are in an appendix
It would seem that the AA code is pointing to your system likely either entering sleep or waking from sleep...however D3 is listed as "Some of the Architectural Protocols are not available"...zero clue what that means
That link is to your motherboard manual in case you don't have one. Is your system doing anything untoward or is it working fine and simply displaying these codes?
