Need help with Microphone jack for my Headset
fluxylynx
Hello,
Recently I purchased a Turtle Beach Earforce X12 Headset but for some reason when I try to talk through the microphone nothing happens, like the microphone isn't there.
In the Sound, Recording section it says that the Microphone is a default and works fine. But, when I click on it the Jack light is red and it says "Front Panel 3.5mm Jack"
The headphones work fine but the microphone doesn't. I have tried updating the drivers several times but no success, I believe it's something in the system configurations but I have no
clue what it might be.
Thanks for help!
Hello,
Thanks for help!
Forgive me if this sounds obvious but which jack is the mic plugged into?
Spuff
Expert
If your mic input shows red in Windows Sounds it would indicate 'not plugged in'. As Spyder suggests, are you plugging in to the correct socket?
