need help?
ClaytonJoness
does anyone know if i would be able to use a blackmagic intensity shuttle on this spec..
AMD PHENOM II X6 1075T (3.00GHz/9MB CACHE/AM3/) - BLACK EDITION
ASUS® M4A78LT-M: mATX MAINBOARD, DDR3, USB 2.0, SATA 3.0Gb/s
INTEGRATED GRAPHICS ACCELERATOR (GPU)
2nd Graphics Card
NONE
Memory - 1st Hard Disk
1TB WD CAVIAR GREEN WD10EARS, SATA 3 Gb/s, 64MB CACHE
2nd Hard Disk
NONE
RAID
NONE
1st DVD/BLU-RAY Drive
2nd DVD/BLU-RAY Drive
NONE
NONE
350W Dual Rail PSU + 120mm Case Fan
STANDARD AMD CPU COOLER
Network Facilities
2 PORT USB 3.0 INTERNAL PCI EXPRESS CARD
Phoenix
I would recommending getting a graphics card like the HD5450 or better but apart from that you'll be fine.
Nemesis
I would recommend a minimum of a 450W PSU for that spec + a GPU
Not necessary but highly recommended as it will potentially improve the lifetime of your PC and allow for upgrades!
