TLDR:
- Have had this laptop for ~4 years with no issues. (No Warranty)
- Last week one of the fans (left side) decides to make a constant loud noise whilst the keyboard vibrating like an electric toothbrush.
- Only happens when a game or a browser with a video is open/playing
- Contacted PCS, if the issue is the fan they no longer have the fans in stock.
- Contacted a private vendor they ran a diagnostic and mentioned the graphics card is damaged as well as the fan unit.
- It looks like the 2 fans are actually one unit, so if one is broken I have to replace both - Not sure if this is true
Question I'm asking is, do I pay the £95 and send it back to PCS to investigate what the actual root cause is, or do I just try and find out the fan unit specs and try and replace the fans myself....
Any help on this would be very very helpful.
Specs:
Chassis & Display
Defiance Series: 15.6" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo)
16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 180W AC Adaptor
1 x 1.5 Metre Cloverleaf UK Power Cable
Battery
Defiance Series Integrated 3 Cell Lithium Ion Battery (73WH)
1 x THUNDERBOLT 3 PORT + 3 x USB 3.2 PORTS
Keyboard Language
15" DEFIANCE SERIES UK KEYBOARD
Specs:
Chassis & Display
AC Adaptor
1 x 180W AC Adaptor
Battery
Keyboard Language
