New PC cooling fans question
Willid1
New PC build - should both these CPU fans be running all the time or just the second one (OPT fan) when load requires??
Willid1
Yes this is a PC specialist system. I'm having trouble getting logged into my PC Specialist account and don't have a copy of the build spec, but the Order Number is 2774065 if that's a help​
David
Willid1
Promotional Item
Promotional Code ZZ-PCS-6RP5-X276-BT02
Terms & Conditions
Intel® Core™ i9 16-Core Processor i9-12900K (Up to 5.2GHz) 30MB Cache
ASUS® PRIME Z790-P (LGA1700, DDR5, PCIe 5.0)
32GB PCS PRO DDR5 4800MHz (1 x 32GB)
DVD/BLU-RAY Drive
NOT REQUIRED
CORSAIR 650W CX SERIES™ CX-650 POWER SUPPLY
DeepCool AK620 ZERO DARK High-Performance Dual Tower CPU Cooler
Extra Case Fans
2 x 120mm PCS Black Case Fan
ONBOARD LAN PORT
NOT REQUIRED
Welcome Book
PCSpecialist Welcome Book
Willid1
Thank you - the reason I asked is the AK620 ZERO DARK cooler actually has 2 fans in it, I assume they both spin at the registered cpu_fan speed? and are fed by a single cable?
David
