So I've ordered my new pc from pcspecialist
however, does it come with a Windows 10 trial on it for free?
And if it does, when it runs out is there an option to put in a license key to continue it?
Wise choice.
It will have a version of Windows 10 on there which PCS have used to test the PC. However, this copy of Windows 10 may not be complete nor configured properly. Personally I would never recommend that anyone attempt to use the PCS test version of Windows for production purposes.
AFAIK yes you can. However, given my above comment, you're much better off reinstalling Windows 10 cleanly (with a valid key of course) rather than try to use the PCS test version.
Ok, could I get the Iso file online and put it on a USB and then boot from the USB?
