I don't know if you guys could give me some technical help? Below is the initial issue and the steps I have taken:
Issue:
Troubleshooting:
If a CPU failure and the MOBO was working ok wouldn't it come up with warning beeps or a message on screen of some kind? If so do you think likely MOBO failure instead?
Are there any other troubleshooting I could do other than replace the MOBO/CPU? The PC is very old but was functional for my needs. I can only get used CPU/MOBO now due to how old they are but considering giving it a try.
Any thoughts if possible welcomed.
Issue:
- Turned PC on, all lights came on and fans but no POST beep or signal to my monitor.
- Turned it off/on a few times and it started cutting all power after a few seconds.
- Opened PC up and took 1 RAM module out and it booted fine.
- Put same RAM module back in same slot to confirm that was the issue but it booted fine as normal.
- Then it started to start to boot and the power just died again.
- Looked further and CPU Heatsink wasn't secure as the plastic push pins appear to have broken.
- Didn't try PC any further as was worried about damage to CPU.
Troubleshooting:
- Brought new heatsink and fan.
- Took thermal paste off CPU with appropriate cleaning fluid and repasted CPU and fitted heatsink and fan.
- Booted PC, fans came on, MOBO light on, but no POST beep and no signal.
- Checked PSU with PSU tester and it appeared faulty.
- Replaced PSU and tested it with PSU tester and all appeared fine.
- Installed PSU but have same issue, MOBO light on, fans all spin but no POST beep or signal to my monitor.
- Tried taking RAM out separately and completely but same issue happens.
- Took GPU out and tried to boot but same issue happens.
- Replaced CMOS battery but same issue remains.
