No Sound (jack & built-in speakers)
Hey there,
Just bought a brand new Recoil Series. I have no sound.
The only way for me to hear something out of this laptop is from bluetooth / from my second monitor.
I updated the drivers from the device manager, reset / reinstall windows but nothing's working..!
Any help would be gratefully appreciated
Châssis et affichageRecoil Series : Écran large LED mat 15,6 pouces 165 Hz sRGB 100 % QHD (2560 x 1440)
Processeur (Unité centrale)Processeur Huit Core AMD Ryzen™ 9 5900HX (3,3 GHz, 4,6 GHz Turbo)
Mémoire (RAM)64 Go Corsair 2666 MHz SODIMM DDR4 (2 x 32 Go)
Carte graphiqueNVIDIA® GeForce® RTX 3080 - 16 Go de RAM vidéo GDDR6 - DirectX® 12.1
1er disque SSD M.21 To SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (jusqu'à 3500 Mo/R, 3300 Mo/W)
2e disque SSD M.21 To SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (jusqu'à 3500 Mo/R, 3300 Mo/W)
Lecteur de carte mémoireLecteur de carte mémoire SD intégré
Adaptateur C.A.Un adaptateur secteur 230 W
Câble d'alimentation1 câble d'alimentation européen, 1 m (C13/14)
BatterieBatterie lithium-ion intégrée de 94 WH série Recoil
Pâte thermiquePÂTE THERMIQUE ARCTIC MX-4 EXTRÊME CONDUCTIVITÉ
Carte sonHigh Definition Audio 2 canaux + prise MIC/casque
Bluetooth et sans filGIGABIT LAN ET KILLER™ WI-FI-AX 1650 M.2 GAMING + BLUETOOTH 5.0
Options USB/Thunderbolt1 PORT USB 3.2 (Type C) + 3 PORTS USB 3.2
Langue du clavierCLAVIER PER-KEY FRANÇAIS RÉTROÉCLAIRÉ RGB
Système d’exploitationWindows 11 Famille 64 bits - Licence mono-utilisateur incluse
Firstly, have you fully installed windows and drivers after reinstalling? Could you take a screenshot of your windows update and optional updates from advanced options?
I see SpyderTracks is troubleshooting the more likely causes first, and I do recommend doing that first before suspecting you need an OEM fix, but I had the same issue and this was the solution: https://www.pcspecialist.co.uk/forums/threads/no-audio-after-rma.86102/#post-657866
Hey Rairun, thanks for your answer. I truly appreciate your help. It sound a lil' more complete than just windows update. As the computer is brand new..
I read all your thread and I'm not sure to understand few points :
- Whats is the OEM fix ?
- What means "reboot" ? Just turning off power or re-install windows ?
I'm still kinda of a noob and i would appreciate if you provide me more details of how you proceed with this OEM Fix.
Thanks again!
here you go (attached)
