NZXT Sentry 3 Fan Control
erhboy
hi just wondering how hard is it to fit and wire up the NZXT Sentry 3 Fan Controller to my new desktop
It should be reasonably easy. However, it may not be worth it vs other solutions like PWM case fans with Asus Suite (or maybe even in the BIOS?). Or Speedfan or something. Note that the Sentry doesn't use the CPU's own sensor to monitor the temperature, it has a probe that you need to tape to/near the CPU. So it's temp reading for the CPU won't be very accurate.
http://www.neoseeker.com/Articles/Hardware/Reviews/nzxt_sentry_3/2.html
http://techgage.com/article/nzxt-sentry-3-fan-controller-review/
http://www.gamersnexus.net/hwreviews/1505-nzxt-sentry-3-fan-controller-review
http://www.tweaktown.com/reviews/64...ouch-screen-fan-controller-review/index4.html
erhboy
hi i`v got Ai Suite 3 installed but that only finds and see`s 2 of 4 fans in the case so i thought maybe it need a controller
You'll want to check how the fans (especially the two that aren't being controlled) are plugged in. Are they plugged into the mobo, or into a cable/hub that's basically plugged right into the PSU? Follow the cables from the fans :)
erhboy
hard to see it looks like the rear one go`s to the mobo the top one the Corsair H100i V2 Hydro Cooler w/ PCS Liquid might go to a cable/hub and the twin front fan go`s into a cable/hub
jerpers
Master
The fans for the H100i v2 go to the controller on the pump unit and can be controlled using the corsair link software.
In that case it may be that you can control the case fans at the rear that are plugged into the mobo, while the two front two fans are plugged into the PSU. If your motherboard has spare chassis fans headers I'd look to plugging them in there, in your position.
