Octane III fan spins at max
NiroshB
I recently brought (03months ago) 15.6" Octane III basically fr doing 2d/3D Animation in windows 10 operating system,Howevr last week i had weird thing,Laptop fan spins at max even when PC is turned off.Before that i update windows 10 & VGA Driver ( Usuay Auto updates both )Anyone had a clue.Please Respond.
Thanks.
Chassis & Display Octane Series: 15.6" Matte Full HD IPS LED Widescreen (1920x1080)
Processor (CPU) Intel® Core™i7 Quad Core Processor i7-6700k (4.0GHz) 8MB Cache
Memory (RAM) 16GB HyperX IMPACT 2133MHz SODIMM DDR4 (2 x 8GB)
Graphics Card NVIDIA® GeForce® GTX 1060 - 6.0GB GDDR5 Video RAM - DirectX® 12.1, G-SYNC
1st Hard Disk NOT REQUIRED
M.2 SSD Drive 512GB SAMSUNG SM961 M.2, PCIe NVMe (up to 3200MB/R, 1700MB/W)
Memory Card Reader Integrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
Power Supply 1 x 230W AC Adaptor
Power Cable 2 x 1 Metre UK Power Cable (Kettle Lead)
Sound Card Intel 2 Channel High Definition Audio + MIC/Headphone Jack
Wireless/Wired Networking GIGABIT LAN & WIRELESS INTEL® AC-8260 M.2 (867Mbps, 802.11AC) +
BLUETOOTH
USB Options 3 x USB 3.0 PORTS, 2 x USB 3.1 PORTS, 1 x USB 2.0 PORT
Battery 2 x Octane Series Battery Pack, 82WH (One Spare)
Álvaro
Could you be more specific? It cannot be spinning when it is powered down unless something is really wrong with it. Do you mean on idle? Also, can you check your temps?
Try as well to press FN+1. That forces the fan to maximum speed. If you see a change when you do then that may be part of the problem, maybe some sort of false contact (I am hardly an expert)
