Optimus V 13.3 Network not connecting
Joshhay
When I try to connect by wifi to any network it doesn't connect and says connection is limited, this means I cannot connect
Also neither of the programs ( Nvidia graphics card set up and Soundblaster) have started correctly and crash on opening
It was delivered today
I'm glad you sorted it but those issues all sound to be driver related, so it might be worth checking that all the drivers are installed and that none need upgrading.
Genome
if you continue to have connection issues like i did with my optimus using a killer wireless card, i solved it by installing older drivers.
