Hi, I have bought an overclocked system from PC specialist and I had some questions, here is my spec:
Case ZALMAN Z11 PLUS BLACK MID TOWER CASE
Overclocked CPU Overclocked Intel® Core™i5-3570k Quad Core (3.40GHz @ max 4.60GHz)
OC Settings Show/Hide
AI Overclock Tuner: XMP
BLCK Freq: 100
Turbo Ratio: 46
By All Cores: 46
Internal PLL OverVoltage: Auto
Mem Freq: 1600
EPU Power Saving: Disabled
Load-Line Calibration: Auto
CPU Manual Voltage: 1.375
DRAM Voltage: 1.65
CPU Spread Spectrum: Disabled
CPU Ratio: Auto
CPU C1E: Disabled
Motherboard ASUS® P8Z77-V: PCI-E 3.0 READY, WIFI, SLI, CROSSFIREX
Memory (RAM) 8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (2 x 4GB KIT)
Graphics Card 2GB NVIDIA GEFORCE GTX 670 - 2 DVI, HDMI, DP - 3D Vision Ready
Memory - 1st Hard Disk 500GB WD CAVIAR BLACK WD5003AZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
Power Supply CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£69)
Processor Cooling Corsair H40 Hydro Series High Performance CPU Cooler (£39)
Extra Case Fans 2 x 12CM Black Case Fan (configured to extract from rear/roof) (£9)
Change to: NONE
Thermal Paste ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND (£9)
I was wandering a few things;
-If I did overclock, how would I underclock (If such a thing even exists)
-Is it safe depending on my specs (Is my airflow good, what about my power)
-What happens to my 1 year silver warranty if I overclock via AI Suite II
Sorry if some of these questions are really stupid, I'm still learning about computers.
Thanks in advance.
BLCK Freq: 100
Turbo Ratio: 46
By All Cores: 46
Mem Freq: 1600
DRAM Voltage: 1.65
CPU Ratio: Auto
CPU C1E: Disabled
Change to: NONE
Thanks in advance.
