Overclocking settings for I7 2600K
LFFPicard
Godlike
Overclocking will void the warranty on the CPU if it was to fail due to the overclock, but if it was a overclocked system by PCS there is two options.
Go into the bios and one of the screens should be a O.C Profile screen, usually PCS would have saved your overclock settings to one of the profiles so try loading the profile up.
Failing that I believe they may have been posted on your notes from testing/QC if not do a quick search of the forums i swear they got posted somewhere, but you best bet is to find the settings used on your machine specificly from the tech notes as these are known as stable on your machine.
If you can't find the details either give them a call in the morning or open a ticket to tech from your admin pages and someone will pick it up tomorrow and reply.
Good luck!
silkysean
4.8Ghz Settings - 1.000v idle - 32 degrees/ 1.344 - 1.368v Max Load - 85 degrees!(Prime Stable 24 hours)
AI Overclock Tuner: Manual
BLCK Freq: 100.00
Turbo Ratio: Enabled (All Cores)
By All Cores: 48
Internal PLL OverVoltage: Enabled
Mem Freq: (AS PER YOUR RAM)
EPU Power Saving: Disabled
Load-Line Calibration: High
VRM Freq: Manual Set to 350
Phase Control: Extreme
Duty Contorl: Extreme
CPU Current Capability: 100%
CPU OverVoltage: Offset Mode
CPU Offset: + 0.060
DRAM Voltage: (AS PER YOUR RAM)
VCCSA Voltage: Auto
VCCIO Voltage: Auto
CPU PLL Voltage: Auto
PCH Voltage: Auto
CPU Spread Spectrum: Disabled
CPU Ratio: Auto
Intel Adaptive Thermal Monitor: Enabled
Intel Virtualization: Disabled
Intel SpeedStep: Enabled
Turbo Mode: Enabled
CPU C1E, C3, C6: Enabled
4.6Ghz Settings - 1.000v idle - 30 degrees/ 1.3v Max Load - 70 degrees max (3 weeks stable)
BLCK Freq: 100.00
By All Cores: 46
Load-Line Calibration: Regular
CPU Offset: + 0.070
VCCSA Voltage: Auto
VCCIO Voltage: Auto
PCH Voltage: Auto
CPU Ratio: Auto
Turbo Mode: Enabled
LFFPicard
Godlike
As mentioned in my last post it is probably best to contact PCS and clarify as the above settings may be stable and working on silkysean's machine but Killzoned may be slightly different for various reasons..
The settings may have been tweaked slightly per machine for stability reaons as even though the same components are used they may behave differently to being overclocked.
Killzoned
Thanks for the response, By any chance LFFPicard are yours Overclocked? As we have similar specs
P8P67 PRO
COOLIT ECO ALC 240
CORSAIR 1000W
120GB INTEL 510 SERIES
2TB BLACK CAVIAR
GTX 580
8GB DDR3 HYPER X
Window 7 64 bit
