PC case and fans
Grumple
Just received my pc, it says on the side that some fans may have been removed to fit in the foam, it doesn't look like there is any side panel fans attached to the case but i can't find any anywhere else? am i being stupid and it should be like this/ are they anywhere else? or is there something wrong D:
Oh and the case is the cm 690 ii
Just read something on a website about the case, in the specs it said "Left side: 120 / 140 mm fan x 2 (optional)" maybe thats why? its not supposed to?
Corfate
They may have been removed so that your GPU or CPU cooler can fit in there. Most likely, thats what's happened :)
tom_gr7
Life Serving
Did you order the fan controller with the extra case fans? If so they should be there. IF not dont worry the case just doesnt come with the side fans as standard and you can add your own. :)
