Jacob Hobbs
Hi All,
I am looking to upgrade my old "gaming" computer to bring it somewhat up to date to be able to handle games, looking to gift to a family member. It was built by PC Specialist in 2017 but looking to install/upgrade everything myself.
It doesn't have to be able to be a beast just something that can handle games and run comfortably. I'll be breaking down what I will be reusing from my previous build and if I am looking to replace. Please feel free to make comment if you think I should be replacing a certain part even if its not down to be replaced. By no means a experience builder.
Please let me know your thoughts and whether or not I will run into issues that I am unaware of. Looking to spend under £300.
TIA.
Jacob
COMPONENT | CURRENT BUILD | NEW BUILD |
CPU | Intel® Core™i5 Six Core Processor i5-8600K (3.6GHz) 9MB Cache | Keep same |
CPU Cooler | Corsair H55 Hydro Series High Performance CPU Cooler | Keep same |
Motherboard | ASUS® PRIME Z370-P: ATX, LGA1151, USB 3.0, SATA 6GBs | Keep same |
Memory | 16GB Corsair VENGEANCE DDR4 2133MHz (2 x 8GB) | Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory |
Storage | 2TB SEAGATE BARRACUDA PRO 3.5", 7200 RPM 128MB CACHE | Keep same plus installation of 1TB M.2-2280 NVME SSD (Windows to be installed to) |
GPU | NVIDIA GeForce GTX 1070 8 GB | Keep same |
Case | InWIN GT1 BLACK GAMING CASE | Corsair Carbide Series 275R ATX Mid Tower Case |
Power Supply | CORSAIR 550W VS SERIES™ VS-550 POWER SUPPLY | Keep same |
Wireless Network Card | WIRELESS 802.11 AC1900 1,300Mbps/5GHz, 600Mbps/2.4GHz PCI-E CARD | Keep same |
TIA.
Jacob
