PC Crashing - help please
TVByrne
I bought a PC for my daughter in June, she now tells me that whenever she boots up Minecraft or Discord the CPU goes to 100%, which shuts off the PC and it has to be restarted, losing games and progress. I'm not technical so relied heavily on the 'check' function in the ordering system.
What advise/fix can you suggest
Processor (CPU) Intel® Core™ i7 Eight Core Processor i7-11700 (2.5GHz) 16MB Cache
Motherboard Gigabyte B460M DS3H V2 (rev. 1.0) : LGA1200, DDR4, USB 3.2
Memory (RAM) 16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
Graphics Card 6GB NVIDIA GEFORCE GTX 1660 SUPER - HDMI, DP - GeForce GTX VR Ready!
1st Storage Drive 1TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
Memory Card Reader USB 3.0 EXTERNAL SD/MICRO SD CARD READER
Power Supply CORSAIR 450W CV SERIES™ CV-450 POWER SUPPLY
Processor Cooling PCS FrostFlow 100 RGB V3 Series High Performance CPU Cooler
Network Card 10/100/1000 GIGABIT LAN PORT
Wireless Network Card WIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD
USB/Thunderbolt Options MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating System Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001]
Operating System Language United Kingdom - English Language
Windows Recovery Media Windows 10 Multi-Language Recovery Image - Unlimited Downloads from Online Account
Office Software FREE 30 Day Trial of Microsoft 365® (Operating System Required)
Anti-Virus BullGuard™ Internet Security - Free 90 Day License inc. Gamer Mode
Browser Microsoft® Edge (Windows 10 Only)
If you're still using Bullguard I'd strongly suggest you fully uninstall that first. It's well known on here for causing issues and you really don't need it, Windows Defender is plenty good enough.
If it still crashes without Bullguard please post back and we'll do some more detailed troubleshooting.
TVByrne
Hi there, thanks for the answer, she says she has deinstalled it already
Im aware the discord overlay can cause issues steps to disable it
To disable it entirely:
Click on the System Tray to show hidden icons.
Double-click the Discord icon.
Click on the Settings icon.
Click on Overlay on the navigation bar.
Switch "Enable in-game overlay" to off.
Could you please upload the event logs? The post here explains how to do that. It's possible they're small enough to upload direct to the forum, if not upload them to the cloud somewhere with a link to them here.They will help us see what problems are occurring on the PC. :)
TVByrne
Apologies, we dont know how to access the event log. however on the cpu usage the thing that is using 100% seems to be Open JDK platform Binary.
TVByrne
Its the overlay of discord not discord itself she would still be able to use discord
Switch "Enable in-game overlay" to off.View attachment 28129
what does doing this do to help can i ask?
That's the Open Java Development Kit. Some app that you have that uses Java is most likely the culprit then. That sounds more like a misbehaving app than a hardware or system problem.
TVByrne
oh okay thank you for your help, do you have any tips on what to do or am i just going to ahve to leave it?
Just google Minecraft 100% CPU, there are loads of threads about it
Make sure you're using the 64Bit version of minecraft and not 32bit
It's just a case of finding which bug relates to your setup.
