Hello everyone,
I'm trying to build a fast machine that I could use as my main workstation to do 3d graphics (3ds Max, Cinema4d) and compositing (Nuke, after effects). My main two questions would be:
1. which processor would be faster - 6 core i7 extreme or the Intel® Xeon® E5-2687W? A lot the times I'm doing lighting and final 3D rendering and I just need to get fastest preview possible, so would 8 core Xeon render the frame quicker then i7... I know you could potentially overclock that i7 to make it run even more faster, what about Xeons? Can you overclok them?
2. Would sticking another Quadro 4000 graphics card would make any difference for lets say Vray RT or any other program that has GPU accelarated stuff?
Here is my specs that I put together.. Feel free to share your thoughts and opinions..
Thanks
Max
Case AeroCool X-Predator Evil Black Full Tower Gaming Case
Processor (CPU) Intel® Core™i7 Six Core Processor Extreme i7-3970X (3.5GHz) 15MB Cache
Motherboard ASUS® P9X79 WS - SOCKET 2011, QUAD DDR3, USB 3.0, SATA 6 GB/s
Memory (RAM) 32GB KINGSTON HYPERX GENESIS QUAD-DDR3 1600MHz X.M.P(8 x 4GB KIT)
Graphics Card PNY QUADRO 4000 2GB GDDR5, 256 CUDA CORES, 2 x DP, 1 x DVI-I
Memory - 1st Hard Disk 240GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd Hard Disk 480GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 540MB/sR | 450MB/sW)
3rd Hard Disk 3TB WD CAVIAR GREEN WD30EZRX, SATA 6 Gb/s, 64MB CACHE
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply CORSAIR 750W PRO SERIES™ HX750-80 PLUS® GOLD MODULAR (£119)
Processor Cooling COOLIT ECO II C240 DUAL RAD LIQUID CPU COOLER (Special Offer) (£55)
Extra Case Fans NONE
Fan Controller NONE
Sound Card ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities 2 x ONBOARD 10/100/1000 GIGABIT LAN PORTS
Operating System Genuine Windows 7 Professional 64 Bit w/SP1 - inc DVD & Licence (£109)
Thanks
Max
Fan Controller NONE
