heza121
Hi all, I have put together 2 specs with the help from PCS Live support. If anyone could offer their opinion/advice/improvements, it would be greatly appreciated. Just so you know I will be using the pc for gaming such as (BF3, Cod, MC etc), video/photo editing, Web Design, iTunes (hence the large HDD). I would also like to be able to run up to 4 monitors off of it, would this be possible. Which spec would you recommend and why? Budget is around the £1850-£1900 mark. thanks. Also i was having difficulty choosing between the graphics cards :S
Thanks in advance!!
SPEC 1:
COOLERMASTER CM690 MKII ADVANCED CASE
Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V: USB 3.0, SATA 6GBs, NVIDIA®SLI™, ATI®CrossFireX
16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (4 x 4GB KIT)
2GB NVIDIA GEFORCE GTX 560 Ti - 2 DVI,HDMI,VGA - 3D Vision Ready
Memory - 1st Hard Disk
80GB INTEL® 320 SERIES SSD, SATA 3 Gb/s (upto 270MB/sR | 90MB/sW)
2nd Hard Disk
3TB WD CAVIAR GREEN WD30EZRX, SATA 6 Gb/s, 64MB CACHE
3rd Hard Disk
1st DVD/BLU-RAY Drive
12x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£79)
2nd DVD/BLU-RAY Drive
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72)
Network Facilities
ONBOARD GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI-E CARD (£19)
4 PORT USB 2.0 INTERNAL PCI CARD + STANDARD USB PORTS
Microsoft® Office Home & Student 2010 (1 License Product Key Card) (£82)
NORTON 360 SUITE - 1 Year Licence for upto 3 PCs (£39)
DVI-D & HDMI Monitor Cables
2 x 2 METRE DVI-D CABLE (£9)
Miscellaneous
FREE Batman Arkham City with any Nvidia® GeForce GTX560 or above!
Quantity
1
Price: £1,682.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/mainstream-intel-sandy-bridge/
And SPEC 2:
Intel® Xeon® Quad Core E3-1280 (3.5 GHz, 4.80 GT/s)
ASUS® P8P67 WS REVOLUTION (NEW REV 3.0) - ATX, USB 3.0, SATA 6 GB/s
16GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (4 X 4GB)
2GB NVIDIA GEFORCE GTX 560 - 2 DVI,HDMI,VGA - 3D Vision Ready
2nd Hard Disk
3rd Hard Disk
Network Facilities
8 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Miscellaneous
Quantity
1
Price: £1,895.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/intel-1155-workstation/
Thanks again!!
Thanks in advance!!
SPEC 1:
2nd Hard Disk
3rd Hard Disk
Network Facilities
Miscellaneous
Quantity
1
And SPEC 2:
2nd Hard Disk
3rd Hard Disk
Network Facilities
Miscellaneous
Quantity
1
Thanks again!!
