Go to the order in your main account, select the order, then scroll down and click on upgrade order, the upgrade configurator will show up and you can order them via thatIs it possible to buy these from PCS separately. I have some on my new PC but I want some more.
Nothing else in the box? Sometimes they come with male to male connectionsHad to contact PCS as they sent me a box of 8 x ARGB Strips - should there be connectors so you can link them together as I wanted to add them to the 2 already in my PC?
This is what they sent
It's only one pin that's missing, the pin that's missing marries up on bothSo they have sent me those - as the ARGB Strips are 3 pin do I just cut these connectors into 1 pin and 2 pin and connect ?
Yes, you cut off the one pinso I cannot just connect them as they are
Yep, this is what I did to convert some RGB extensions to ARGBYes, you cut off the one pin
