JSG10
Expert
Hi all,
I've been doing some transcoding of videos files in Vuze recently and noticed that ALL cores are at 100% while doing this and that the CPU fan is really going some.
So I loaded up CPUID HWMonitor and I'm seeing the fan at 45-4600RPM and temps of 66-67 degrees Celcius on each core.
I looked up the temp range for the 970 and from what I can see max is around 62 :S Should I be concerned?!
Any idea why it should be getting so hot? Wouldn't have thought it such a CPU intensive task, certainly not to this extent anyway.
