Please check need advice | PCSPECIALIST
Arellano
Hello im planing to order new PC from psc, i would like to get a little advice about setup im planing to buy :)
Mainly the pc will be used for gaming.
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
Intel® Core™i5 Quad Core Processor i5-4670 (3.4GHz) 6MB Cache
ASUS® Z87-A: ATX, USB3.0, SATA6GB/S, SLi, XFIRE +
8GB KINGSTON HYPERX BEAST DUAL-DDR3 2400MHz X.M.P (2 x 4GB KIT)
2GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready
Memory - 1st Hard Disk
1TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB CACHE
1st DVD/BLU-RAY Drive
CORSAIR 650W ENTHUSIAST SERIES™ MODULAR TXM-650 V2-80 PLUS®
Corsair H60 Hydro Series High Performance CPU Cooler
Creative Sound Blaster® Audigy Rx
1 x 2 Metre UK Power Cable (Kettle Lead)
Arellano
8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
3GB NVIDIA GEFORCE GTX 780 - 2 DVI, HDMI, DP - 3D Vision Ready
1TB WD CAVIAR BLACK WD1003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
CORSAIR 650W ENTHUSIAST SERIES™ MODULAR TXM-650 V2-80 PLUS® (£79)
Super Quiet 22dBA Triple Copper Heatpipe Intel CPU Cooler (£19)
What about now? I'm thinking about sound card but I might just take it from my old computer as I bought it not that long ago.
Arellano
Ok thank you very much and i have question do you have any idea is the game that come as "free" are digital version or is it game code?
