My budget is around the £2500 mark and I intend to use this machine for gaming, with heavy flight simulation use, some CPU-intensive games, photo and video editing. I would like to make this machine capable of producing moderate results over the next, say, 5 to 8 years. My current machine is on its 8th year and now my wife is allowing me to buy a new one. I cannot, as some suggest, simply spend half this amount now on a good computer, then spend it again in 3 or 4 years' time, as my wife does not understand that sort of thing - to her a new computer is a new computer, regardless of whether I spend half of the amount - so I will be stuck with whatever I buy now for the next, say, 6 years minimum. I'd love to hear your opinions on this spec, if you have the time. So, without further ado, here goes:
CORSAIR OBSIDIAN SERIES™ 750D FULL TOWER CASEThe only case which is cheaper and allows the H100i is the Fractal £85 job, but it looks a bit small and less effective at cooling than this. It also doesn't, in my opinion, look as nice, and I would lose the top fan to the 100i, further reducing the cooling. So, I opted for the 750D
Overclocked CPU
Overclocked Intel® Core™i7-4770k Quad Core (3.50GHz @ max 4.40GHz) longevitymwith a 4770k. I may be able to run what I want on an i5, but this thing has to keep on trucking for years to come. With the flight simulation itself being CPU intensive, as is the photo and video editing, I am inclined to go for this. Overclocking as it is only £9 for a PCS overclock so why not, if it'll help squeeze that little bit more out of it in a few years' time
ASUS® SABERTOOTH Z97 MK1: USB 3.0, SATA 6.0GB/s, THERMAL ARMOR possibly the most controversial part of my build. The thermal armor is said to do an excellent job at reducing the amount of dust in the motherboard, and the thermal armor actually works well at heat dissipation, which I expect to prolong its life. I could go for the cheaper variant but, after quite a bit of soul-searching, I'm concluding that the little bit extra I spend now could help save me a headache 5 years down the line
8GB KINGSTON HYPER-X FURY DUAL-DDR3 1600MHz, X.M.P (1 x 8GB) Cant see why I would need more at the moment, but I fully expect to upgrade this in a couple of years. I don't think I need the Beast 2133
3GB NVIDIA GEFORCE GTX 780 Ti - 2 DVI, HDMI, DP - 3D Vision Ready It is a lot of money, but this machine has to last and it'll be running at 1440p so could use the extra punch. I contemplated two 4gb 770s, as they show far better 1440p performance, but decided that it would be too expensive to upgrade well in the future. Whereas it'll be relatively cheap at that point (say 3 years down the line) to buy a second 780ti to SLI, whichll, give me maybe 30fps more than the two 770s at 1440p
Free Item
FREE WATCH DOGS with GTX 660 & 7 Series GPUs!
1st Hard Disk
500GB Samsung 840 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW) This will be my main drive, housing everything a desktop computer could want, including games. I don't have that many installed at any one time so this seems like enough space without being overkill
2nd Hard Disk
4TB WD CAVIAR BLACK WD4003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm) A large hard drive for a lot of files. At the moment I'm running on about 2.7Gb of space used up, and expect to reach the 4gb capacity within the next few years. An easy upgrade to buy another hard drive in the future.
1st DVD/BLU-RAY Drive
CORSAIR 1000W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET (£139) I only need 650W for this build, but when I buy another 780ti, which I expect to do in the next 2 or 3 years, I will need 1000W according to the calculator. Interestingly, with the BenQ gaming monitor (the 24inch 144htz one), I would require a 1200W PSU, whereas with the ASUS this is apparently sufficient. I think that's a bit odd
Corsair H100i Hydro Series High Performance CPU Cooler (£89) Another controversial aspect I'm sure, but it'll prolong the life of my CPU and, considering the overclock, having this over the H80i seems like the smart move. Besides the difference is only about £15 or so
10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs Toyed around with the expensive wireless getup, but I believe that homeplugs are a better choice.
NO OPERATING SYSTEM REQUIRED already owning Windows 7 Professional
Microsoft® Office Home & Student 2013 (1 License & Disc) (£85)
Monitor
ASUS 27" Professional SERIES PB278Q (£464) This has excellent reviews. It was between this and the iiyama equivalent, but the portrait view won it out for me, that and the excellent reports of pretty much zero backlight bleed
3 Year Platinum Warranty (3 Year Collect & Return, 3 Year Parts, 3 Year labour) (£135) Because when you're spending £2500 on a machine, why not?
PCS EXTRA-CARE DIAMOND DELIVERY - MON-FRI, PRE-NOON (£9) Please take extra super-care of my machine
Standard Build - Approximately 11 to 13 working days We shall see!
Quantity
1
Price: £2,528.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-haswell-overclocked/bvL2n_XUEP/
Overclocked CPU
Free Item
1st Hard Disk
2nd Hard Disk
Monitor
Quantity
1
