Please help, first custom build
kfryer
Thanks in advance
Need the large RAM, good cpu and two GPU cards to run two types of chess analysis software. Not really a gamer. Like to upgrade RAM in future.
Advice re storage, cooling and the rest would be much appreciated.
FRACTAL DEFINE R6 BLACK QUIET MID-TOWER CASE
AMD Ryzen 9 3950X 16 Core CPU (3.5GHz-4.7GHz/73MB CACHE/AM4)
The Outer Worlds -AND- Borderlands 3 w/ select AMD Ryzen CPUs
ASUS® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - RGB Ready!
64GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 16GB)
8GB NVIDIA GEFORCE RTX 2070 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
2nd Graphics Card
DVD/BLU-RAY Drive
PCS FrostFlow 120 Series RGB High Performance Liquid Cooler
Extra Case Fans
SCOTTISH HIGHLANDS & UK OFFSHORE ISLANDS / N IRELAND
Promotional Item
Welcome Book
Price: £2,817.00 including VAT and Delivery
Simultaneously I take it, each GPU doing maths for one of the programs?
The ASUS X570-PLUS should be fine and is a lot cheaper. You'll have perhaps seen the configurator whinge that the PLUS doesn't support SLI. However, you're not going to be using SLI for this kind of dual GPU work. Worth arguing the toin coss with PCS tbh as spending extra for a motherboard you don't need isn't good.
You will want a much better CPU cooler than this. e.g. H100i / H115i Platinums. This is a powerful processor that puts out a fair amount of heat, and also the cooler you keep it, the higher the frequencies it can maintain.
Consider the Corsair 680X. Not because bling RGB, but because it is excellent for GPU cooling and you've got 2 high end ones in there.
The 2x extra case fans fitted to the 680x on the bottom (the CPU AIO cooler going up top and the other fan mountings being populated by the stock fans) will be great for feeding the GPUs fresh air.
kfryer
Thank you for advice. I had a feeling that I was skimping on the cooling.
I have attached a link for the reasons for the two gpu's.
Thanks again
Kim
If that's the basis, then a single 2080 ti could be the better purchase?
If you look at the comments, some random person says:
promatix 11/15/2019 01:01
Best value per1$ RTX 2070 61 ns/1$ 2080 Ti 33 ns/1$ so its better buy two 2070 than one 2080Ti
But, the article author replies:
Albert Silver 11/15/2019 11:17
@Promatix - Those speed numbers you quote are inaccurate. I know someone with a dual 2070 setup and his speed on the start position is around 40knps. With the 2080ti alone I get around 36-37knps. Remember also that two GPUs also means double the power consumption and a much larger and more expensive power supply.
The table of speeds quoted in the article is:
Graphics cardNodes per second
RTX2080ti
37000​
RTX2080 Super
32000​
RTX2080
29500​
RTX2070 Super
28000​
RTX2070
24500​
RTX2060 Super
22500​
RTX2060
18500​
GTX1080ti
9000​
GTX1660ti
8500​
GTX1660 Super
7700​
GTX1650
3800​
GTX1060
3000​
GTX1050ti
2500​
GTX1050
1700​
So, you do not get 100% scaling with a 2nd GPU (as would be more common in something like Octane renderer, or certain synthetic game benchmarks. A 2070 - assuming Albert Silver means a 2070 and not 2070 Super (2070 sometimes gets used to mean 2070 Super) - gives 24.5k NPS. Double that obs is 49k NPS. Albert Silver says he knows someone running dual 2070s gets only 40k NPS.
The dual GPU setup costs about the same as am RTX 2080 ti, needs to you have a better PSU, consumes more power, produces more heat, and needs better cooling for the system. And PCS also want you to have a more expensive motherboard. And you said you're not really a gamer - if you do do any gaming, dual GPU setups aren't easy and often give no extra performance, just so you're aware.
A 2070 Super x 2 setup might be a little faster than a single 2080 ti, but it does involve a dual GPU setup and all the negatives that brings.
I'd suggest considering either: a) going with a single 2080 ti, and getting a cheaper system overall because you don't need to buy all the extra / upgraded bits to manage dual GPUs or b) get a 2080 ti, and spec the system so you can add a 2nd one if you think you might want to and have the money.
Nomad
So I won't profess to know exactly what software you are running for what you actually need in terms of CPU/GPU balance, though Id take the above advice on the GPUs.
Things I will comment on:
I am unsure on that motherboard choice. Something like the TUF Gaming Plus which I know PCSpecialist definitely has is better than the X570-F. It's partly preference, but it's better VRM cooling for cheaper which is reasonably essential if there's high CPU loads, which Id consider as you have a 3950x.
You actually don't need liquid cooling at all, and all in one "water cooling" are NOT to be mistaken for custom loop water cooling. They are nowhere near the performance, but nowhere near the price. I've viewed them mostly as just cosmetics. Proper air cooling solutions like Noctua have are far more effective than all in one (closed loop) water coolers especially at the same price. The 3950X under heavy loads and even somewhat substantial OCing (depends on the bin) can survive well on a Noctua U14S (U14a) I can confirm that both of the motherboars above have enough clearance to allow it to fit in the top PCI-E slot. You might also consider the Noctua D15, which pretty much blows any cooling system thats twice its price out of the market for only £100 or so. It'll honestly last you ten years minimum, and Noctua are very good about releasing new mounting systems for pre existing coolers so you're covered for new sockets.
The ram pretty much? Has to change. Again I am partly relying on you requiring the CPU heavily, and when it comes to AMD third gen in the higher end you need to get ahold of 3600Mhz ram to match the infinite fabric as close as possible; you get noticeable performance increases. Preferably CL16, but CL18 won't be the end of the world. Lately Ive found the UK has lost most of its 3600C16 models and the price for what's left is extortionate, so there's no real problem in budgeting down by 3600C18 which Im pretty sure is all PCS sells.
Storage is entirely up to you, but I wouldn't worry about those cheap drives too much. Id possibly just get the smallest drive PCS sells, and individually buy your own drives later. If you don't care about speed, a 5400RPM WD Blue is the most reliable drive on the market, with 4TB only costing about £85. You could step up to WD Black for a bit more performance if you can afford it, or you can also go with a 1tb m.2 drive option like the sabrent rocket (PCS don't really offer any good ones) + some 5400RPM storage like the WD blue.
The PSU is pretty good. No complaints.
As I said, you want to get an eye on those GPUs, and I don't particularly do much in the way of GPU loads that my 2080S is stressed enough to require an additional GPU. As long as you steer clear of things like the MSI Ventus GPUs, try and avoid palit/zotac if its not too much trouble but nothing too wrong if they are, and try and aim for EVGA especially for it's RMA, you'll be in a good situation. I do agree with the suggested switch to a 2080TI though, as we're talking two 2070S here not two 2080S.
Enjoy your build, sounds like a mammoth when it's done.
Not sure anyone mistook open and closed loop cooling.
However, the Noctua isn't as effective as the (granted more expensive) Corsair Platinums, which are very good for their class. Given the way AMD's 3000 series boosts, keeping the CPUs as cool as possible will help performance, and the R9 3950x does use a fair amount of power and benefit from as good a cooling solution as you can reasonably afford.
As for the NH D15 'blowing any cooling system twice its price out of the market' ... no. As excellent as it is for what it is... and I can't really believe this even came up as a question...
Also PCS no longer sell the NH D15 anyway. That seem to stop being on sale shortly after a few reports of damaged PC systems from it coming loose in transit (wince). Though that could just be coincidence.
If we're doing the whole "3600MHz is best for Ryzen" thing, to the point of saying things like "the 3200MHz has to change" and there is a "need" for 3600MHz - which given actual testing seems to be overstating it a touch and reliant more on the comments AMD made at launch, then we really do need to make sure we pay attention to CPU cooling and boost frequencies too.
As for:
That's .. I'm not sure what that's based on, but even if factually accurate which I don't see how anyone could prove given the difficulty getting statistics for that, the % differences will be ludicrously small. For actual data, one could look at Backblaze or
https://www.hardware.fr/articles/962-6/disques-durs.html (albeit a bit old now, the French one)
But neither of these are representative of the whole market or what all consumers should consider the most reliable.
The WD Black HDDs are, simply put, just not worth it. If you want a 7200rpm HDD there are many cheaper options.
