Not even for a little one? ðŸ˜ðŸ¤£ (OS drive)
250GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6400MB/R, 2700MB/W) more then enough for windows 10 and updates wont be using that drive for anything else and im one of those that does a clean install every 6 - 8 months so should be sufficient but in a ideal world would be 500gb maybe by time march rolls around i will change itNot even for a little one? ðŸ˜ðŸ¤£ (OS drive)
The 500gb is faster though (i think)🤪250GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6400MB/R, 2700MB/W) more then enough for windows 10 and updates wont be using that drive for anything else and im one of those that does a clean install every 6 - 8 months so should be sufficient but in a ideal world would be 500gb maybe by time march rolls around i will change it
Got to go fast 👀The 500gb is faster though (i think)🤪
nvm i changed it to 500gb cos it was £50 more had it in my mind it was alot more bad ash no bad man bad influence !!!!The 500gb is faster though (i think)🤪
Got to go fast 👀
Change to: 500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W)
My ssd is over 70% full and the speed difference is basically unnoticeable, i think a 70% full 980 would almost certainly still be faster than a 10% full PCS one.In all seriousness upgrading the M.2 on my build from the 1tb PCS one is the only thing I keep looking at. I did consider getting a faster 512gb but I want to Chuck flight sim on it
How big is Windows 10 roughly out of curiosity? Don’t actually have a system with it on at present 😂.My ssd is over 70% full and the speed difference is basically unnoticeable, i think a 70% full 980 would almost certainly still be faster than a 10% full PCS one.
It’s roughly about 35Gb just for the OS, but then you have OneDrive storage and other things which can bloat it if not moved to another drive.How big is Windows 10 roughly out of curiosity? Don’t actually have a system with it on at present 😂.
Flight Sim is 150gb but realistically 200gb down the line. So a 512 sammy could be realistic
(I have a 2tb sata SSD for other games/files)
Pre-Production | 5 working days |
