Problem with PCI-e card USB-C 20Gb/s card, with certain specific files only.
David689
A few weeks ago I bought a PC from PC specialist - see below, although this doesn't show that I added a second M2 drive and two SSDs and a HDD to the order too.
I fitted the following card myself:
This was in order to have a gen2x2 USB 3 socket that would have a theoretical max transfer rate of 20Gb/sec. I bought it in order to use with my portable SSD:
https://www.westerndigital.com/en-g...isk-extreme-pro-usb-3-1-ssd#SDSSDE80-2T00-G25 - the 2Gb one.
But it is exhibiting strange but thoroughly reproducible behaviour. The portable SSD has nearly 40,000 images on it, and the corresponding Lightroom catalogue. The images are in various formats - various RAWs, JPEGs and some TIFs.
The short story is that only some specific files cause problems via the PCI-e card but not via the motherboard USB socket (both USB-C).
The much longer story is:
When the SSD is plugged in to the expansion card's USB gen2x2 (ie 20Gb/s) socket I have tried dragging and dropping the folder that contains all the images and the Lightroom catalogues and previews etc onto one of the internal SSDs (2Gb). It starts off copying the files. But when it reached a particular file I got the error message
"An unexpected error is keeping you from copying the file. If you continue to receive this error, you can use the error code to search for help with this problem.
Error 0X800701B1: A device which does not exist was specified.
IMG_0301-Edit.tif
Item type: TIF File
Date taken: 16/7/2012 18:40
Dimensions: 3403 x 5104
Try again Skip Cancel"
Clicking "try again" simply resulted in the same error message. Going to "This PC" I noticed that the drive (J:) had disappeared, hence the error message.
So I rebooted and the J: (portable SSD drive) reappeared. I navigated to IMG_0301-Edit.tif on the J: drive via "This PC", with the window set to display thumbnails but the thumbnail displayed was a generic "image" thumbnail - the picture of a paintbrush. Clicking on it to open it I got the error message:
"Windows photo viewer can't open this picture because the file appears to be damaged or corrupted or too large".
I tried renaming the image to IMG_0301Edit.tif (ie removed the dash), rebooted and went through all the above again, with the same results.
I then rebooted and opened, in Lightroom, the catalogue containing all these 40,000 images. In Lightroom (grid) I searched for and found IMG_0301Edit.tif. No thumbnail was displayed. Clicking on it to open the file resulted in Lightroom becoming unresponsive, and after several minutes I had to ctrl-alt-delete to stop Lightroom.
So next I plugged the external SSD into the motherboard's USB gen2 (ie 10Gb/s) socket on the backplate and it performed flawlessly. I was able to copy the entire contents, including IMG_0301Edit.tif across to the internal 2Gb SSD. Via "This PC" I was able to see the thumbnail of IMG_0301-Edit.tif as a miniature of the picture and clicking it opened it in Windows Photo Viewer. I was able to find it in Lightroom and to open it in the Library and Develop modules.
The .tif file was not important so I deleted it. I shutdown, plugged the external SSD into the PCI-e card's USB-C (gen 2x2 20Gb/s) socket, formatted the internal 2Gb SSD card and dragged the folder containing all the images and Lightroom gubbins from the external drive into the internal SSD drive. Again, everything started OK but then I got the same error message as above, but with a different file, IMG_0394-Edit.tif. I did everything that I described above with exactly the same results - using the motherboard's 10Gb/s socket it behaved perfectly, but using the PCI-e card 20Gb/s socket all the same problems as above occurred.
But it was only with certain specific files that the problems occurred. I was able to drag and drop hundreds or even thousands of other images from the SSD via the PCI-e card and was able to view and preview many other images on the drive.
The entirely reproducible nature of the problem makes me wonder if this is not due to a hardware fault but something that may be fixable.
I have tried Googling for a driver for the card but the Gigabyte support site doesn't even have a section for PCI-e cards.
I have done a fresh reinstall of Windows 10 as described in these forums but the problem persists.
If anyone has read this far, then thank you. Any advice gratefully received.
12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Standard Build - Approximately 14 to 17 working days
Welcome Book
Logo Branding
PCSpecialist Logo
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/agBbN92cFJ/
IMG_0301-Edit.tif
Item type: TIF File
Clicking "try again" simply resulted in the same error message. Going to "This PC" I noticed that the drive (J had disappeared, hence the error message.
Welcome Book
Logo Branding
PCSpecialist Logo
Could you take a screenshot of your device manager page?
And your windows update page?
David689
sck451
This is not by any means a solution, but it's worth noting that the USB SSD you link is a USB 3.2 Gen 2 drive, rated for a maximum of 1050MB/s. This is only half of what the 3.2 Gen 2x2 interface is capable of. The motherboard's own interface is 3.2 Gen 2, so (unless I have read this wrong) you shouldn't actually see any performance benefit from being attached to the expansion card.
I would test the drive out of the USB C port on the motherboard, speeds are going to be no different as the drive is limited to 1050mbs which the USB C port on the motherboard can support.
Test it in there just to verify if it's the same behaviour.
If it is, for me, it would point to the drive, not the port that's the issue, possibly power related and it's not getting enough juice.
EDIT: Sorry, just read that it is working fine out of the motherboard port.
The speeds won't be any different as @sck451 correctly says, as the drive is the limiting factor, not the port.
But nevertheless, I'm unsure why the card wouldn't be working other than it's a faulty card.
David689
I may have linked to the wrong one - this is the correct model https://www.bhphotovideo.com/c/prod...e81_2t00_g25_2tb_extremepro_portable_ssd.html
Just for further details, the card I think doesn't require drivers as it uses the chipset drivers, and runs power off the PCIe lane
Even the direct ASMedia page doesn't contain any drivers:
What may be worth trying if you haven't already is manually updating the chipset driver as windows is known to install the wrong version:
David689
What you say about speeds makes sense. But PC Pro magazine reviewed this model
(link copied from magazine) and said:
"The SanDisk Extreme Pro is one of the first external drives that we've seen that uses the USB 3.2 Gen 2x2 standard. When it's connected to a compatible socket , it can sustain speeds of up to 20Gbits/sec.
"The catch might be the 'compatible socket@ part - even on the newest laptops and desktops, 2x2 ports are still rare. If you don't have one, you can plug this drive into a regular USB socket for now, and look forward to a big speed boost when you next upgrade your computer.
"Alternatively, for a desktop system you can buy a PCI Express card that adds the requisite USB connector for around £30.
"That's what we did and we don't begrudge the investment at all. With sequential read and write rates of over 1,800MB/sec, the Extreme Pro's performance over a Gen 2x2 connection vies with low-end NVMe drives. Multithreaded performance isn't quite so stellar, but this SSD was still around twice as fast as drives using the older 10Gbits/sec connection. That makes it a super choice for any outboard storage role: the PCMark benchmark suite gave it a data disk score of 1,788, second only to the Adfata SE900G."
You've posted two different models, so that was based off the first one you posted.
If it was the second then it is Gen 3.2 2 x 2 which is a different speed.
David689
Ha!
Well what do you know? That may have done the trick! I updated using the link you posted. And I have been able to view the "rogue" file in question in Explorer through the 20Gbit/s card. I have now drag/dropped all the files from the external SSD to an internal one and await progress with interest. Thank you both for taking the time to read my ramblings and for, quite possibly, having fixed it.
David689
Ha!
Doh! Nope - the file transfer failed again, in the same way. Ah well. So you think it may be a faulty card? I should seek to return it.
It may just be a slightly dodgy card.
The only other thing I can think to try is try it in a different PCIe slot.
