Recently I purchased a Proteus VI, but i've had to send it back because the right click mouse button wouldn't work properly as well as the battery life being only an hour. At the moment it is sent in for a refund as i've found the same spec cheaper elsewhere, but i'm considering exchanging this to a Vortex IX as i've had good services with PCS in the past so would like to keep the business with them. I was looking at the Vortex IX as a potential exchange given I had issues with the Proteus and was wondering which would be the better spec?
Both are essentially identical and very similar price, only difference is the Proteus has a RTX2070 vs the Vortex with a RTX2060, however the vortex does have Gsync. I don't know much about Gsync, all I know is the RTX2070 is a fairly significant amount better than the 2060 so was wondering if the Vortex would be the better option or not given the issues with the design of the Proteus as well as the battery. Also the Vortex does have an 9th Gen CPU as well, but i've read that isn't all that much better than the 8th gen.
The spec that I bought for the Proteus was this: £1488
The Vortex build is the following: £1517
Chassis & Display
Vortex Series: 15.6" Matte Full HD 144Hz LED Widescreen (1920x1080) + G-Sync
Intel® Core™ i7 Six Core Processor 9750H (2.6GHz, 4.5GHz Turbo)
Get Total War: Three Kingdoms & More w/ select Intel CPUs!
32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
NOT REQUIRED
AC Adaptor
1 x 180W AC Adaptor
Battery
Vortex IX Series 6 Cell Lithium Ion Battery
COOLER MASTER MASTERGEL MAKER THERMAL COMPOUND
2 Channel High Def. Audio + SoundBlaster™ Cinema
Bluetooth & Wireless
1 x USB 3.1 PORT (Type C) + 2 x USB 3.0 PORTS + 1 x USB 2.0 PORT
Keyboard Language
MULTI COLOUR BACKLIT UK KEYBOARD
Thanks for any comments.
Chassis & Display | Proteus Series: 15.6" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080) |
Processor (CPU) | Intel® Core™ i7 Six Core Processor 8750H (2.2GHz, 4.1GHz Turbo) |
Memory (RAM) | 32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB) |
Graphics Card | NVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1 |
1st Storage Drive | NOT REQUIRED |
1st M.2 SSD Drive | 500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W) |
Memory Card Reader | Integrated SD Memory Card Reader |
AC Adaptor | 1 x Proteus Series 230W AC Adaptor |
Battery | Proteus V Series Lithium Ion Battery (7180mAh) |
Power Cable | 1 x 1 Metre UK Power Cable (Kettle Lead) |
Thermal Paste | COOLER MASTER MASTERGEL MAKER THERMAL COMPOUND |
Sound Card | Intel 2 Channel High Definition Audio + MIC/Headphone Jack |
Bluetooth & Wireless | GIGABIT LAN & KILLER™ WIRELESS-AC 1550 M.2 GAMING 802.11AC + BLUETOOTH 5.0 |
USB/Thunderbolt Options | 3 x USB 3.0 PORTS + 1 x USB 3.1 Type C PORT AS STANDARD |
Keyboard Language | PROTEUS SERIES RGB BACKLIT UK KEYBOARD WITH NUMBER PAD |
Chassis & Display
NOT REQUIRED
AC Adaptor
1 x 180W AC Adaptor
Battery
Keyboard Language
