Hi.
The Coolermaster 690 II advanced case is compatible with top AND bottom 240mm radiators. However, the PCSpecialist configurator does not allow for the CoolIT ECO 240mm radiator to be paired with the case. Is it really not compatible?
Thanks in advance.
I have investigated this further and the reason why we do not offer this fan is because the fit is very, very tight, and more often than not the 12V motherboard power connector can be "in the way" and literally pressing against the radiator.
I would therefore recommend you consider the standard ECO fan (the difference is not huge between the two, in terms of CPU temps).
