How would they know you had overclocked it if you sent it back?
Forensic analysis of your system, yeah hunting those illegal overclockers down
All I did with my R9 280x was download the power tuneup program for powercolor, downloaded furmark, from this you need to try and balance things by monitoring your temperature, voltage and FPS/throttling.
You do need to increase the voltage for the highest overclock a GPU can achieve, but you can get a respectable overclock without touching the voltage, which for me is the point you sail off the edge of the world.
On my thing I believe it's just the limit I'm increasing, I think the voltage is regulated by the chip and it uses what it wants while in the limit I've gave it, I could be wrong though.
For normal overclocking and temperature testing I use Unigine Heavenbench or Unigine Valley. My reason for this is Unigine give a good representation of a game whereas Furmark does not.
[/url]
HW Monitor will show you the maximum temperature reached during a game or anything else. I like it because it is a very light and simple application that can be left on.
