Quiet case vs Airflow case for noise
Tom_P
I've recently ordered a PC (gaming use) but due to supply issues (Ryzen 3300x processor) it's been in pre-production for a while, so I've inevitably been tweaking the spec and second-guessing my choices...
The bit I'm currently thinking about is, if I'm trying to reduce noise, am I better off going for a quiet case, but with the risk of the fans having to work harder because of the worse airflow; or going for a better airflow case, and then having less load on the fans to achieve adequate cooling so actually ending up quieter? I've put my build in below for info - currently with the Corsair 275q quiet case; the 275r airflow works out a bit cheaper as I won't need the extra case fans I've specced here.
Any advice or suggestions would be helpful!
CORSAIR CARBIDE SERIES™ 275Q QUIET CASE
AMD Ryzen 3 3300X Quad Core CPU (3.8GHz-4.3GHz/18MB CACHE/AM4)
STANDARD AMD CPU COOLER
Extra Case Fans
Standard Build - Approximately 16 to 18 working days
Promotional Item
Get Rainbow Six Siege: Gold Edition with select NVIDIA GeForce RTX GPUs!
Welcome Book
Logo Branding
PCSpecialist Logo
Tom_P
Thanks both - as you've guessed, that's a bit beyond my price range unfortunately, already stretched the budget to get to the graphics card! It sounds like I should go with the better airflow and then tune the fans or possibly just get quieter fans later to get the best balance.
Tom_P
Hi Nursemorph, thanks I'd heard good thinks about the Focus G (I think it was the recommended case in the example builds) but was put off by the aesthetics - is it possible to turn off the lighting on the front fans? Because of where it's going I want to avoid something that looks like Blackpool Illuminations flashing away!
You're the opposite to me, my last PC was uber quiet and discrete as I was room sharing when I bought it. I have my own study now and my desk looks like it's hosting a rave due to the amount of RGB in it.
The Fractal ones look quite classy as they're just white LEDs.
