FerrariVie
The overall results are not too bad, as according to 3Dmark the average of your build should be somewhere between 21k and 25k. However, your physics (CPU) score is particularly low and there is indeed something weird: your RAM frequencies. Don't think it is related to hardware and it is likely a configuration change that needs to be done, but I'm afraid I can't be of much help on how to solve this on your particular machine (I'm more knowledgeable on Clevo and AMD builds).Standard:
I scored 21 780 in Fire Strike
Intel Core i7-11800H, NVIDIA GeForce RTX 3080 (notebook) x 1, 65536 MB, 64-bit Windows 11}www.3dmark.com
Undervolt (clock frequency capped at 1.320 MHz)
I scored 20 634 in Fire Strike
Results seems pretty disappointing for my brand new Recoil, considering my specs...and temperature seems very high too!
Maybe I got a very unlucky components...Shoud I have to contact PC Specialis support?
My advice is that you open a new thread asking for help on the "Technical Advice"area and mention that your 3Dmark results were showing RAM frequencies of 1333 Mhz, when it should have been 2666 (from what I can see on your signature):
And by the way, can't understand why you cheaped out on the RAM frequencies. On such an expensive build, RAM frequencies should have been prioritized versus RAM size (choosing 32Gb 3200/3000 instead of 64Gb 2666 would have been a lot better imo). But that can also be discussed on the new thread that you're going to open.
